White Beo4
Good solution............for a major production!!!!!!!!!
Oh, I dunno. I picked at random a couple of local print houses that have their price lists on the net. For a single colour screen print on small objects, the initial costs including films etc seem to start from 30 euros and the actual printing work per piece is practically free (less than 50 cents per piece, in series from 20 pcs on). Can't see why they wouldn't do just a few for the total cost of the smallest series.
They might have something to say about what kind of paint they can print on etc, but you'll never know unless you talk to a print house... πŸ˜•
Will Check it. Thanks for the idea!!
Looks great Spiros, although I'm not convinced about the display frame in white. I think that's a personal taste.
Just finished 4 others including the BL1000.
Still not satisfied about the logo.
WOWWWWWWWWWW!!!!! I got to have one Beolink 1000!!!!!
Something that may be worth thinking about is printable water-slide decal paper. Similar to the decals we used to get with Airfix models (and other makes).
See link or
Exeter,
Devon,
UK
I agree that the inner display frame should be left alone. Beo4 no. 2 looks great without white frame except the lines down either side they are too much I think - white is best.
I would also cover up the text even though the control would look a little top heavy. Only other little niggle I have is the black bit between the arrows..
The link 1000 looks soo good I might paint mine! Trying to figure out if it would be going a little too far to paint the lower plate white too?
Oh heck had to play with PSP before posting - Hope you don't mind me using your picture Leslie!
Not at all, in fact I was thinking about letting somebody doing some airbrushing on one of my remotes. Sometimes you see those wonderfull art looking pictures on trucks/motorbikes. Just a thoughtπŸ€”
You could pull it off, IMO it would have to be a clever design, contemporary (no camouflage patterns!) and ideally quite simple.
Maybe a Burberry or Louis vuitton pattern πŸ˜•
