Beocom 6000
I was tempted by
Probably older than 4 years as they are version 1.  Bases look compatible though - 1st is the controller base, 2nd is wall-mounted charger, 3rd is table-top charger.
Juan is correct, I have a near identical setup. Mine is MkI version and must be just over 10 years old as they were bought when they first came out in 1999 (since had updated software to run a Beocom2). The silver pyramid base is the Phone base unit, and I have the same wall charger and 2 further black table chargers. (+Beocom2 & charger base) and all handsets compatible with each other and fit each base. (except Beocom2 naturally).
Stoobie
Exeter,
Devon,
UK
