BEOCOM 6000 MK1
Hello All,
Can anyone provide me with the following info the Beocom 6000 MK1 Version has the Grey colour rear case been changed since its introduction in 1999 to the present Grey of 2012 by this I mean has it always been light grey as the 2012 version or has there been a darker grey at some point different shades of grey.Thank you
The rear cases are very easily interchangeable so although the Beocom 6000 MK1 came in a particular shade of grey, the newer covers will fit.
link page shows what models came in which colours in which years but does not tell you what shade. I am aware of 3 different shades of grey on the Beocom 6000. There is a very pale grey (almost sand colour) then there is a light grey (almost the same colour as the MK1 Buttons) and a darker grey. There is also the black.
Photo This is the lightest grey. I have seen this colour and it is in between the current "white" and the colour of the buttons on the MK1 handset. (it is sort of a putty colour)
I have this colour and it is a definite grey and almost an identical match for the buttons on the front of it (MK1 handset)
Large photoThis picture shows the third grey I have seen. The phone on the bottom right has a cover that is a darker grey than the other two pictured above (it is not the black as that can be seen next to the green on the top left)
Obviously the colour reproduction in the pictures is not 100% but I'm confident I have seen 3 shades of grey. Not all on the MK1 (but interchangeable)
Stoobie
Exeter,
Devon,
UK
