Beosystem 2500
Dag B&O vrienden
Ik heb een Beosystem 2500 bouwjaar 1991. Deze ziet er nog steeds als nieuw uit en doet het nog perfect.
Alleen als de deur automatisch opent, dan blijft de motor vaak lopen - schakelt niet af.
Iemand een idee hoe ik dat kan repareren?
Ook blijft de laatste tijd het groene ledje branden als het apparaat uit is.
Nogmaals alles werkt verder prima en ik wil hem graag nog jaren gebruiken.
Alvast bedankt voor de input
Hans
Hi
Rephrase your quistion in english and I will ty to help
regards
jan
Hi Jan
My inglish is not that goed
I have a beosystem 2500 from 1991. It works fine.
But when the glas dors are opens the motor don't stop. You have to pull out the plug and than it works normal (the doors are closing automatic).
Is ther somting to clean so that it work normal again?
Thanks for you input
Hans
Hi Hans
There are two possibilities you must remove the glass doors be carefull when you do so the  way to remove them are as follows,Set the doors in open state unplug the 2500 then carefully pull the top of the glass door against you then do the same in the bottom of the glass door they are fastened with a metalpiece that fits into a plastic clip clean the glass both outside and inside with what we use for cleaning windows also clean the black plastick piece where the remote sensors are located
the second possibility is the switch located on the motor pulley that drives the opening and closing of the glass doors but thats inside the 2500 and you have to take the 2500 apart and I don't know your skill's with such things:but try the first solution first
regards
jan
Thanks Jan
I dit clean the windows and the sensor, but no improvemend.
I will open the 2500 next week. My skills are good enough to open it. Off it is good enough to close with all parts in place? We will see this week. Is there a par👍tikelar part to clean when i open it?
Thanks in advance fot youre afort
Hans
Hi Hans
Clean or replace the switch located on the motorpulley that drives the closing and opening of the glass doors its in the left side of the 2500 where the drive motor are located.
regards
jan
Dat groene LEDje gaat uit als je de radio uit hebt staan en dan op de radio op mute duwt 😁
En dat van die motor is waarschijnlijk de schakelaar van de motor zoals Jan al zei.
Hi Beomaster8000
Please give me that in english
regards
jan
It works🙂
I put on he radio and pusht the mute . The green light dit go out.
I also cleand the switch on the motor for door movement and on the moment al works fine. And i have no spare parts after rebild.
Thanks for al the help
Hi Hans
Happy to hear that
regards
jan
