Service manual repository
I’ve just renewed my Gold membership. It now works. Damn. I really had no idea. I didn’t get the end of subscription warning as I used to. Sorry.
Jacques
Bang & Olufsen classic service centre.
Repairs and refurbishment to both old and new.
I need the manuals for a Beovision 7-40
Hi, I have added the BeoVision 7 service manuals  link
Hi Mark
one thing I have noticed in the manual repository is the text that tells you to Upgrade your membership to view documents. This might be intended, but it shows up even if I am logged in and could potentially confuse someone if they don't see any documents for a given product.
I don't know if it should be rephrased or what not, but now you know.
Correct. Before, you had no access to service manuals at all, unless you were at least silver I believe. Hence my confusion.
And the whole website remains desperately sluggish, by the way 😩
Jacques
That is correct, on the old site there was not access. I believe you should be able to see what is available before deciding on becoming a member. Almost a look at what you are missing" 😂
Thanks Mark,
And good luck on this herculean task.
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Thank you, guys. It's great to get things resolved so quickly. Just a couple of oddities noted.
  1. In the new BV7 area: Page 7 of the Instructions area lists:
Blu-ray Guide MKV - EN -BeoVision 7-40 MKV Blu-ray Guide However the link is to a BV7 Mk3 service manual, instead of the correct document. 2. The Service manual area includes manuals for Mk1 to Mk4, but nothing for Mk5 and Mk6. Are those manuals unavailable? Mark
Blu-ray Guide MKV – EN -BeoVision 7-40 MKV Blu-ray Guide
This now goes to the correct file
