Report Problems with the Site Here
Hi Mark, When I try to upload a picture using the "insert image" key of the menu bar, the message "upload failed for xxx". I used small size jpg files in order to minimize the load on the server and they are uploaded without problem as an attachment. But it is far less practical since you cannot insert images to illustrate your "words. Where is my mistake? It might be useful to add "how to" guide as a sticky note. Kind regards, Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Bang & Olufsen classic service centre.
Repairs and refurbishment to both old and new.
Sorry Mark,
Now it shows : Invalid nonce.
Regards,
Yann.
ok, I will keep on it.
It's working fine from my side, but this could be to do with my user level.
Test post
Test It worked.
I also got this error today, and ended up attaching files instead of inserting pictures in the Beolink 5000 repair thread. In the same thread Guy have inserted pictures without issues
I'm struggling to see any reason for it, Guy reached via email so I just did a little test.
I will keep looking, if I don't see anything I may just reboot the server tonight
