Hello everyone! - The future of Beoworld.
Thank you Mark, gold is back!
I just tried the search function. E. g. „Beosound Shape“, „Beosystem 4500“, „Beosound 9000“. Every search seems to be limited to 50 results (per source?). Is this a default setting?
Looking into it now
Bang & Olufsen classic service centre.
Repairs and refurbishment to both old and new.
@patcherley
  1. I think this issue is due to updates being published. When I roll out an update I also clear the Redis server's cache which will force a logout of all users too. Please let me know if it does continue to happen
  2. On the homepage, the last tab has the post topic button. also on most of the forum pages where the breadcrumb bar is, there is a new topic button.
If the feeling is that it should be better located then let me know
Found it, when I looked earlier I couldn't get past Sticky Topics.
I like it in this position.
Thank Paul
There is an issue with posting images in the body of the post at the moment, it will stop the post being made.
I am currently working on this, should be resolved soon.
Rolf2 wrote:I just tried the search function. E. g. „Beosound Shape“, „Beosystem 4500“, „Beosound 9000“. Every search seems to be limited to 50 results (per source?). Is this a default setting?
Should be better now. Might take a bit longer to show the results though,
Testing image pasted in and attached
Also if you do the the following in BeoWorld it generally means that an update is in progress
Attachments (1)
Thank you Mark, „Beosound 9000“ now gets 500 hits 😁! So it is ten times more now 😙.
I find the search very fast and guess it is normal that the search needs - just a little - longer, when more results are found. Great, thank you!
Nice. As I’ve been unable to start a new topic on the previous gen forum, I hope I will now be able to participate again!
