If i take the arm a litle bit more to the center of the disc then the arm lifts and goes back.
I also notice than when the arm goes automatically back, it is not absolutely parallel to the border : in conclusion, my problem i that the arm is not correctly indexed on it's axis.
On the old beogram (the ones from 60 or 70's) it was easy to setup : you unscrew the screw on the bottom of the arm adusjt and then tighten the screw and that's it.
On the modern model i absolutley have no idea on how i can adjust that.
good to know : i had to fix two pins that are holding a part that is used for lowering and rasing the arm... maybe the is an impact on that ? (that part is working good now)
