Beyma 8" woofer equivalents for S45s type 6302
Hi All
Looking for an equivalent 8" woofer for my S45s with the Peerless driver. Is the Beyma Model: 8BR40/N from Spain any good? I'm afraid my woofer isn't measuring any resistance with a meter and woofers are very rarely for sale. Thanks
Alex
These are the T/S specs of the Beyma equivalents
Anyone know if these are close to the originals?
- Fs 30 Hz
- Re 5.5 ohm
- Qms 2.1
- Qes 0.48
- Qts 0.39
- Vas 89.1 l
- Cms 1301 micro m / N
- Rms 1.99 kg / s
- Efficiency % 0.5
- Sd 0.022 sq m
- Xmax 6 mm
- Vd 147 cu cm
- Le @1 kHz 0.5 mH
Hey Alex,
Have you fully diagnosed the original woofer? Sometimes you can get lucky and the disconnect is in a terminal or tinsel lead.
You won't know the real equivalence until someone can locate (or measure) the TSPs of the original transducer.
At first glance it seems that the Beyma driver is better suited for a vented/ported cabinet.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Vas 89.1 l
This alone says no.
I have never seen anything coming close to the original.
