BeoVision Eclipse Gen-1 Front Speaker Grommets
Hello, I have a 1st Gen Eclipse. The grommets that hold the front front speaker have decomposed and have become hard and brittle. Can you get any replacement parts? Thank you Andrew
This has been my temporary solution to the problem. I bought some grommets from Aliexpress:
Black grommet with a 7.5 outer diam and a 5mm inner diam. You will 18 so buy a pack of 20.
I bought 1.5mm thick plastic builders shims. Dimensions 14mmx12mm with an 8mm central hole. A few of them needed cutting down smaller to fit certain constrains. Use a heavy pair of scissors with a grated edge.
This has held the speaker grill on. I am sure if I took the speaker grill of some of them will fall out. I have therefore left it in place with a view of not taking it off whilst I try and source some better fitting grommets.
I have attached some pictures.
