BeoSystem AV 9000 Repair Help
Hi, i got the BeoSystem AV 9000. It now only get power to the AV Unit itself. And shows ERROR 1 and the SW Version. Cleaning the Cable and Port didnt work. I can see the IR LED got one second glow after plugin in the tv. Any help ? or parts on the power supply i have to check ? Thanks!
ERROR 1 means that the monitor cable has been plugged into the Masterlink port.
I played the night before and didnt unplug any cables. Monitor Port is in Control Center Port. I noticed that the status LED on the TOP of the TV isnt RED. I Did clean the Contacts.
