Now I stumbled on a beolink passive amplifer, but it does not have the IR receiver.
I tried connecting it via a masterlink cable to a pair of passive speakers. I believe that "should" work?
Red lamp is on all the time, but no sound.
I was half expecting it to turn green when I powered up the Ouverture.
I read about setting various options in the passive, but it seems like I need the IR reciever to access any setup via the remote. Any hidden controls inside the box?
I do not need any remote control capabilites for the beolink passive as it will be in the same room as the ouverture. I just want a power amp to drive my passive speakers (as a pair of used B&O active spekers are quite costly)
Any ideas?
Would it help to get a powerlink cable instead of the master link cable?
Thanks,
Alf
