I need to find a pair of handles for the Beosound Ouverture wall bracket. I already have the wall plate but not the ears that go on the unit.
They're the one for the wall bracket with two proeminent screw heads in the back, that slots in the plate and the one for the full base for Beosound and two Beolab 5000, that are flat on the back.
I'd like to know if the last ones have the holes and you can add the screws on it or if they are two different pieces that can not be adapted for the wall plate mounting. I can see on the pictures on internet that there is like a tube where the screws should go but I can't see if the hole is there.
Thanks.
