Today I found à Gold Beosound 1*, seems to be the first model, for a very good price (300€).
Of course it had his own issue, namely the top pad is detached from the enclosure and the two ribbon cables are disconnected.
The connectors on the PCB looks damaged too.
Anyway the speaker still works in BT and Airplay and sounds quite good to my ears.
Setup was quite easy even if I struggle to keep connection with the B&O App.
I'd like to know if there is any other way to check the battery level since I've no visual indicator.
And also the battery health maybe?
Thank you for the help.
*Beosound 1, even more in gold, was my first crush for a B&O modern speaker when I entered the B&O world…
