After the "1 2 7 1 trick" the BM4500 seems to work normal.
Will a new battery solve this problem completely?
What are the experiences? Please advice
I've only carried out the procedure on a couple of BC9500s, but no-one else has replied. For me, a new battery solved the problem - I think I had to carry out the COdE procedure again after battery replacement, but there have been no further problems since with either system. In my experience, if you keep the system connected to mains power the problem may not re-occur - my mother-in-law's system failed early because she switched it off at the wall every night. However, if the battery is flat then it may be close to leaking, hence worth replacing.
I'm currently debating changing the battery in a BS3000 that I have taken apart for door/CD belt changes - will probably do so to give it a longer lifespan.thx Is the battery on the minus" side also soldered as the plus side is? It looks like the battery is stuck on the PCB. I opened "the box" also on the opposite side, but it was unclear to me where it was soldered on the PCB (maybe I shoud re-examine it), any help would be appreciated.
I realise it's been a while since the original post but I have just unpacked my old Beomaster 4500 after years of storage and have bumped into the same C0de problem. Typing 1271 play on my remote did not resolve it so I assume I will need to replace the battery. Does anyone know where I can buy a new battery? And can anyone point me towards a guide on how to replace it myself?
Any help and pointers would be much appreciated.
