I acquired a gritty and dirty Beomaster 3300 and (I think) a Beolink1000 for a sixpack of beer this last weekend.
The Beomaster 3300 cleaned up nicelly with a damp cloth with detergent and lots of soft tissue and a toothpick to get the grit and dust of all corners and crevices. The lid-hinge was really badly dirty. It seemed to have been lubricated with some wax-like grease which was not solvable in a normal detergent so had to use a citric acid based lable remover (isopropyl alcohol did not work). I now looks great.
The unit turns on ok and seem to shift between the functions properly, but I have not connected it to speakers yet. I would expect to need to need to clean some potentiometers and maybe change a condensator or two. Will see. I dont know how these units age....
Is this remote a Beolink 1000 ? (picture below)
The batteries where dated "Expiry 2006", so I'm lucky only one had a (small) leak. I cleaned it up, and it looked ok. However, the Beomaster 3300 does not seem to react when I press buttons on the remote. Does the Beolink1000 need to be programmed some way to work with the Beomaster 3300? I am not entirely convinced it has been used together with this Beomaster3300, and as far as i read, the Beomaster 3300 was originally shipped with a Terminal 3000 remote, not a Beolink 1000.
Is it possible to test or understand if the remote or the Beomaster3300 is at fault without having access to another Beomaster3300 system or another Beolink1000?
Login to view image
