1) Is there a way to know what the ideal loudspeaker sensitivity setting (Max Input Voltage )would be-considering that the 3rd party AV processors that connects to, via analog RCA, has a rated output signal of 2 V?
2) should the volume on the BL50 be set to max 90?
Thank you so much for reading this.
