Advice needed on NL/ML setup
After prevaricating for a while on getting a big TV, I decided my office is too small for a really big TV, so I have bought a Beovision 11-46, which I will collect in a few days, and I will continue to use my projector for the cinema experience when needed.  I am off work this coming week too so plan to reorganise my office ready for its arrival, so hopefully I can plug it straight in and link it together with my other equipment when I get the TV here.  I will have:
  • Beovision 11-46
  • Beosound 9000 Mk2, with Beogram 4500 connected as Aux
  • Beosound 5 (set as an audio slave)
  • Beolink Converter NL/ML
  • Beolab 3000 as front surround speakers
  • Beolab Penta as rear surround speakers
  • Beolab 3 as subwoofer
  • Potential (if it's possible) Beolab 7.4 as a cinema centre speaker when using projector
  • A Kramer HDMI Matrix which will allow me to connect my HDMI sources to both the TV and the projector
The only thing I am missing is some adapters to connect my older Powerlink Mk2 cables to the BV11's newer Powerlink sockets - I have one adapter but think I'll need 3 more. I'm assuming that if I connect the speakers to the BV11, then connect the BS9000 and BS5 via the Beolink ConverterNL/ML , I should be able to hear everything via the speakers connected to the TV; am I right in that assumption? I'm also assuming that the BV11 Powelink cables will still drive the displays on my BL3000 and BL Penta speakers - does anyone know if this is the case? Note that if using a BS5 as an audio slave might be too complicated via an NL/ML converter, I also have a BS Moment, but I still prefer the BS5 over it. If I can get all this set up and I'm happy with it, I might finally stop buying stuff and reorganising my office over and over again!
Old enough to have gazed at classic B&O HiFi in Plumbs shop windows in the 80s...
Thanks carolpa.  It hadn't crossed my mind to connect both the BS5 and the Moment, but I suppose I might as well.  They both do the same job - play my music stored on a NAS drive, but the Moment does have the advantage of Deezer too, for which I have a premium account, so that will be useful. I know the sources won't show correct on my speakers, but I've already learned to live with that - I know that N.Music shows as Tape 2 and DVD/Blu-Ray shows as CDV.  I'm glad to hear the displays will work though; it would be a shame to have them and not use them. I only have one Beolink Converter, I'll see how I get on using only one, but you can get them quite cheap on eBay these days so if it doesn't work quite right, I'll get another. Right, I'll start moving things around and routing the cables, ready for the TV pickup on Friday!
I now have the TV, I was short a couple of Powerlink (RJ45 to DIN) adapters and they arrived today, so finally it's all set up. I'm happy to say it all works.  The Beosound 5 is set as an audio slave, the Beosound 9000 is set in Opt.0, and both are connected to a ML junction box, which in turn is connected to the Beolink Converter NL/ML, and that is connected to the Beovision 11-46 TV. All speakers are connected to the TV (Beolab 3000 front, Beolab Penta surround, and Beolab 2 sub). It all seems to work - everything works via the remote (I use a Beo4, Beo6 and Beoremote 1), and if I start to play either the BS9000 or BS5 direct from the unit itself, it also works. The only oddities I have found are:
  • If I use the Beosound 5's own standby button, it stops playing, but it does not put the whole system into standby, whereas the Beosound 9000 standby button does put the whole system into standby.
  • Although I do have Mk2 Powerlink converters, the displays on my BL3000 and BL Penta only show 'TV' and the volume, no matter what source is playing.  Oddly, the speaker displays only work if set to Audio rather than Video - I'm assuming this is just a restriction of the BV11, being much newer that the speakers.
  • My BV11 came with a Panasonic Blu-ray player which is mounted rather nicely on the back.  I have set it up with the PUC cable but for some reason, it powers on whenever I power on the system, rather than only powering on when I set that source.  It also does not power off when I put the system into standby, even though I have set it to do that in the BV11 settings.
I do have one question - I like a bit or retro gaming and I would like to connect my old Nintendo GameCube to it.  I have a S-VHS cable for the GameCube but found that it does not fit into the little round AV socket on the BV11.  Could anyone tell me what kind of plug that AV socket takes?
Yes that was the one 😀 thanks for picking up on it
Thanks for all the help.  I'll keep an eye out on eBay in case one of those official B&O SCART adapters ever comes up, as that would be useful to have. Steve does sell a cable but it's audio only, so I found one on eBay which is 9 PIN Mini-AV to 3xRCA (left, right, video), and I have a GameCube cable that will connect to that.  Hopefully that will work - I'll post here when it arrives.
Update - I received the cable from eBay (9 PIN Mini AV to 3 RCA - Yellow, Red, White) and tried to connect my GameCube to the BV11 with that cable but it didn't work.  All I got was a buzzing noise and a blank screen when I switched the GameCube on.  I'll have to keep looking for the official B&O SCART adapter.
