Beosound 9000+Beolab1+Beolab2 - high-pitched squeak
Hi everyone!!
I have problem with my audio set -
beosound 9000, beolab 1 and beolab 2.
After replacing the cables with mk3, the sound that appeared when changing the volume or track disappeared. But there is a high-pitched squeak. It doesn't change its volume and stays the same all the time from tweeters.
After changing the cables, settings and type of connections between all components, I came to some observations. The squeak appears only when I connect the subwoofer (beolab2) to the system via powerlink. Even if I turn off the power but leave the powerlink, it squeaks. After unplugging the powerlink there is silence in the speakers of beolab1.
I have new mk3 cables. Beolab1 works perfect. I checked te AC power cables.
Thanks for Your suggestions and support
Piotr.
The way you have described everything is phenomenal.
