Hi Guys, It's done, at least for one speaker.
The other one will wait a bit since this is not a really pleasant experience.
That will also allow me to compare Both speaker with new and old foam.
Starting point: the Beolab with stand and fret off and obviously the new set of damping material.
Login to view image
Then take out the screws off: 6 for the amplifier plate, 12 for the speaker plate. All the same.
You need to cut the rubber border use to damp the fret between the two front plates. Use a sharp knife.
Login to view image
The plates are still firmly glued to the pipe. Insert a flat screwdriver and gently pry off the plate. Then progress to the bottom. I used two very useful little tools Thant came with a garden tinsel from a Scandinavian well known brand to open up the two plates, one side after the other.
Login to view image
Login to view image
Login to view image
Login to view image
Disconnect all that should be:
- One big socket between speaker plate and amplifier plate. (white/blue/red).
- One big socket (main power/Yellow) between the amplifier board and the cone.
- Two little connectors between the amplifier board and the cone (3 and 4 wires).
Beware, there is also a third tiny connector much larger (7 or 8 wires), you can disconnect it but it loops from the cone into the cone. Don't mistake it for the one that must be disconnected and pull the plate while it is still attached.
Login to view image
Once everything disconnected, take out the plates: amplifier first, then speaker
Here start the mess! Use gloves.
Foam to be removed is located:
- Just above the cone.
- One the amp board, between the actual amplifier chip and the main board.
- In the gap between the speaker zone and the amplifier zone.
- One big piece in the speaker tube.
Login to view image
Login to view image
Login to view image
The big speaker piece was in my case quite well, sticky and chewy but I was able to remove it easily in one part.
All the other parts were in an advanced state of disintegration, turned into a sticky dust spread all inside the column. You're happy when you manage to take out a big piece!.
Login to view image
Login to view image
Even the foam sealing between the pipe and the plates is rotted. you need to rub it to clean it.
Login to view image
The pipe was vacuum cleaned with the help of alcohol (90°, no isopropyl here in France).
Login to view image
Login to view image
The amplifier board was opened after disconnecting the plugs and cleaned with a brush and alcohol.
Login to view image
To me this is the most scary part: I don't like rub a brush on those PCB with so tiny component. I'm not confident enough to know if this is ok or not and I'l afraid of breaking something or hurting a component. SO I did this carefully with a brush and a vacuum cleaner, take out the most of it but after this, it still remain some sort of sticky touch all over the parts. I think it still better the before.
Login to view image
Login to view image
Before screwing the amplifier board to the Amplifier plate, you need to replace the foam between the chip and the board.
Login to view image
Then clean all the connectors, the speaker socket was particularly dirty.
Login to view image
Then you can start the actual foam replacement. Note that the new set has nothing in common with the previous.
Around the bas port entry.
Login to view image
In the column, roughly in the middle behind were the woofers are.
Login to view image
At the base (rear).
Login to view image
The V shaped one at the bottom of the long strips just above the amp section.
Close the speaker panel and watch out for the speakers wires to go into the foam groove of the V shaped piece.
Login to view image
Correct placement of the foam pieces is are illustrated below. They should make a coffin for the two woofers.
Login to view image
Then, place the amplifier board, plug everything that need to:
- One plug between amplifier plate and speaker plate.
- 3 or 4 plugs between amplifier plate and cone.
Before closing the amplifier plate, add the remaining front base foam piece.
Login to view image
Close the speaker, tight all the screws (18) and check your new foam root proof Beolab 8000!
Hope this helps.
