I have a pair of Beolab 8000 and a Beolab 2 that i want to connect to my amp, i have all necessary Pre-outs, but i have an issue with the beolab 8000 pair where they do not turn on at low volume when using the RCA connection/occasionally turn off by themselves.
I have bought a pair of powerlink trigger cables with Aux (mistake by me to buy AUX as i did not see the powerlink to RCA trigger cable when i bought them) before the Beolab 2 came, and that works just fine on the 8000 speakers, but i was wondering how to do the optimal setup now that the sub is arriving.
I am considering 3 different setups:
1 (temporary setup before cables in setup 2 arrives if needed):
Connect both 8000 speakers to the sub for "power on" information
Sub connected with aux trigger cable to a "aux<->RCA" to amp
8000 connected with RCA cable and set to Line mode
2 (direct connection for all speakers to amp):
Seperate powerlink trigger cables with RCA connected directly to SUB (buy new cables)
3 (sound routing and management controlled by sub):
Connect both 8000 speakers to the sub for audio and power on.
Beolab 2 connected to AMP with Powerlink Aux cable and Aux <-> RCA Left/Right adapter (or eventually powerlink trigger cable with left right RCA).
New on the forum and tried to do a search, couldn't find too much information on my exact situation, hopefully someone on here is able to help, thanks in advance.
