Have been using my Beogram 5500 quite a bit and recently started hearing a sort of quiver when playing a jazz record, I then tried some other albums and heard the same sound, which I believe is called Wow and Flutter.
Given that the LP is fine, the platter is level, I guess it must be down to either the belts on the deck or the stylus.
Am I correct in this? If so is there any advise on swapping out the two belts (band type and smaller round type for arm)
Any help would be gratefully appreciated.
