What is the best pre-amp to Beogram turntables?
Pete,
Where did you buy it and how much did you pay for it?
I'm not really satisfied with my Profitec. To hear my BG5005 I have to put the sound volume up to 60-65!
The only advantage is that it saves me the problem with hand made cables to connect the DIN cable to a RCA pre-amp...
And what is this "QED Discsaver"? I've never heard of it before...
Thanks in advance!
Rather than best it's best value for me........The QED Discsaver is a relatively cheap phono stage that B&O Australia recommended and I have no problems with it. There was a company in Sydney that brought them in. I bought mine from B&O. It compared well against other more expensive units. I got a cable made with the additional earth that stops humming in the earlier turntables.
Jorge,
 I got mine on ebay
Pete,
And how did you manage to connect it to your Beogram and Beosystem?
Did you buy it also? Where?
Is there anyone who knows where to by this kind of cables?
Cheers!
I bought it from the link in my previous post.  He seems a great seller, as it arrived in good time, and well packaged; free postage too.
I use a DIN to RCA phono cable to connect the Beogram to the pre-amp, but I don't have a Beosystem so just have to use phono cables to my HI-FI a Pioneer XC-L5 with the surround processor.
Pete.
