USING BEOGRAM TX2 WITH BEOMASTER 1900
The Beomaster have 5-pin DIN input, but the TX2 have RCA plugs. What do I need to make the TX2 compatible?
You are going to need a male din to female rca phono adapter and then connect the TX ground wire to a screw on the 1900.
Thanks for the reply, much appreciated
