TX 2 Turntable - tone arm
I purchased a TX 2 in magnificent condition which just happened to have a mint MMC1 cartridge! However, when I push the play button the tone arm stops short of the record and platter and my precious MMC 1 lands on the deck. I'm afraid to monkey with the train which carris the tone - How can I correct this. Bill
Hi Bill,
This situation can be corrected with a simple adjustment. It is fully explained, with a drawing, in the service manual which can be downloaded from this site.
Graham: Thanks for advice - For some reason, my computer won't download the manual - do I have to convert the download to another system?
It's a pdf file so you will need Acrobat reader to view it.
Graham: Somehow I lost your answer as to how to repair my TX2' myreply to you is a bit outdated, but if you can find the time to give me another word or two I would appreciate it..Thank you..Bill
You need to download the manual from the main Beoworld website. It will download as a .pdf file and if you have Acrobat reader installed on your computer it should open automatically.
