Hi Beoworld - i've recently had to change my needle on an SP6-7 cartridge, however the replacement styli I purchased, although looks correct and is the one I was directed to buy, doesn't seem to be correct unless I've done something wrong in the fitting. The styli doesn't seem to protrude out of the cartridge far enough out of the cartridge to touch the vinyl, meaning that the back end of the cartridge itself scrapes the vinyl when playing, as the needle is only just touching the vinyl. Is there something I've done wrong in the fitting - it's as if I need to bend (which i 'm not going to!) the needle out of the cartridge to make it protrude enough to touch the vinyl…
Maybe I've purchased a duff, or incorrect styli… is there anywhere anyone recommends to buy a replacement?
Darren
