Set up advice: Beogram 5000 and Beovox S45s.
Hi all,
I have got Beogram 5000 and a pair of Beovox S45s.
Is there any recommendations on connecting these together with a modern pre-amp?
The S45s look like they are 2-pin DIN so guess the why would need to be spliced into a modern connection?
Any advice would be great!
Thanks!
Well, I would look for the matching BeoMaster
https://www.beoworld.org/prod_details.asp?pid=297
But instead of BeoMaster 5000 I would search for 5500
It can be remote controlled with Beo4, Beolink 1000 and the master control panel 5500
