Replacement motor for beogram 1800 5213?
despite attempts at repair, motor is kaput.
are any other beogram motors interchangeable?
Hi Alex,
The motor you need is an BO part 8400110  where on the motor stands MMX-4H2RPB you can find it here
http://www.ebay.com/itm/191650101793?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I bought the same motor 2 days ago who came from a 1800
Kind Regards,
Erwin
Hi Alex,
it is only a shame what Ebay is asking for postal international
Kind Regards,
Erwin
Beogram 1800 Type 5213 does not use a MMX... servo-controlled DC-thingy. It uses a good old one-phase AC-motor.
The later Types 5811-15 however, does.
Sorry missed the 5213 part, then the spare part number is B&O 8401011 would try Beoparts.com how has a lot of Beogram 1800 5213 parts and maybe knows where to replace it with
Regards,
Erwin
That would be the seller rather than Ebay.
And postage HAS become expensive.
