despite attempts at repair, motor is kaput.
are any other beogram motors interchangeable?
Hi Alex,
The motor you need is an BO part 8400110 where on the motor stands MMX-4H2RPB you can find it here
http://www.ebay.com/itm/191650101793?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I bought the same motor 2 days ago who came from a 1800
Kind Regards,
Erwin
Hi Alex,
it is only a shame what Ebay is asking for postal international
Kind Regards,
Erwin
Beogram 1800 Type 5213 does not use a MMX... servo-controlled DC-thingy. It uses a good old one-phase AC-motor.
The later Types 5811-15 however, does.
Sorry missed the 5213 part, then the spare part number is B&O 8401011 would try Beoparts.com how has a lot of Beogram 1800 5213 parts and maybe knows where to replace it with
Regards,
Erwin
That would be the seller rather than Ebay.
And postage HAS become expensive.
