Hi All
apologies if this is a very basic question but I can’t seem to find an answer that isn’t about disassembly.
I have just acquired a 4002 and it needs some TLC on the dust cover to remove blemishes etc. I’m going to use Scratch X but want to remove the cover intact as the springs etc work perfectly so don’t see the need to disassemble the cover from the rear section, just want to remove it from the table.
is it just a case of undoing two screws under the rear? Then what? Pull back, lift off?
thanks for any assistance, I don’t want to get this wrong or break anything.
