I have two BeoGram 5500 turntables. One is working and I use it daily. However it has never been cleaned and serviced as far as I know. The other 5500 has some issues and also needs some service.
I am considering sending both to Pyramid Audio in Austin, TX. It is only a couple of hours drive from my home in Houston, TX. I have used them to repair my Denon DP-45F and they did a good job on it.
There is a shop in Connecticut that has a good reputation for repairing Nakamichi gear, and I plan to send my RX-202 cassette deck to them soon. I see on their website they also repair B&O equipment, but I was hoping to get good work done for less. I think it is $750 for a B&O turntable and $1500 for any other B&O equipment. The prices are on their website.
I see on the SoundSmith website they repair B&O gear.
I would like to hear recommendations on shops to use for good work at reasonable prices. I don't think we should say anything negative about these or any other service companies, but if you have one to recommend, I would appreciate hearing that.
