Want to recap my Beogram 5500 and 6500. Not sure how to get to the solder side of the main PCB or how to remove the power supply board/transformer.
Picture: https://www.dropbox.com/s/e1f912en2sagvcj/beorecap.jpg?dl=0
The motor can be removed in order to replace the little electrolytic there. The larger main electrolytic on the right sits on a PCB held in place by two screws and a clamp at the bottom plate. How to remove it?
Regards
Roger
