Hello Dillen. First of all, thank you for your response. Yes, I am in Argentina and sending it there is not profitable for me. And as you mentioned, something happened during the lubrication I performed, probably malpractice on my part. I found a person on Google with the same problem and they attribute it to a couple of transistors that control the voltage to the main motor and the small belt of the displacement mechanism, so I will try to check the circuit and continue looking for a solution. And also a competent technician here from that brand. Very kind!
