Posted August 30, 2025 at 01:04 GMT
Edited August 30, 2025 at 03:33 GMT
Hi Sr. When I refer to connecting the turntable, I mean 220 volts (mains). Secondly, the turntable does absolutely nothing and has no blown fuses. And the sensor light behind the transparent ruler is an IR LED, it's categorical. I sent you a photo of that LED; it's not incandescent, except for the optical shutter light for the arm movement. Regarding removing the control panel and its circuit board, I work with a grounded static discharge wristband, and I specialize in electronic repair of laptop computers. Audio isn't my specialty, but there's no one in Argentina who understands this brand of turntable. I repeat, the turntable does absolutely nothing when plugged into the mains. And there are no blown fuses. I'm attaching a photo of the IR LED. It's not incandescent. I already tested it with 1.5 volts, and I can only see whether it lights up or not with an infrared lens. Finally, you insist there's no infrared LED. I'll prove it to you. I've already identified the circuit. Please see the circuit in the attached photo. Sincerely.
P.D.: My model, unlike yours, has an IR sensor, not a fluorescent one.
I'm attaching a photo of the IR LED. It's not incandescent. I already tested it with 1.5 volts, and I can only see whether it lights up or not with an infrared lens. That said, please tell me how I proceed from here. Do you have a flowchart?"
