Problem with Beogram 4002 Type 5521
I dont understand that last post?
Good morning. I clarify my last post. Now, when I plug the turntable into a power outlet, the speed control and rear sensor lights come on. If I set the speed to 33 RPM, it makes half a turn and stops, but if I set it to 45 RPM, the motor spins. Without the metal covers, I press the Stop key; the motor (without the belt) that moves the tangential tone arm spins. If I press Start, does it stop? With the belt in place, it doesn't move, as if the threaded bronze shaft were stuck to the right, like it's locked. However, if I insert the covers and set the turntable to play a record, the Start function doesn't activate, nor do the right-left arrow keys. I do press the key to raise and lower the tone arm. I don't know which component controls the speed, because only the motor works at 45 RPM, not 33 RPM. Try recording a video.
Ok....I dont have a manual for the type 5521, however the image you posted of the 5513 position sensor suggest to me that it may be very similar....the speed control is via 1RL1
Hellow hcraig244. I have it, and I also made a video. I'll review what you mentioned in the diagram. Thanks for your input.
You have multiple issues which is making troubleshooting this online very difficult.
First Problem: Plugging in the turntable should NOT cause any lights to turn on on motors to run. Since the 33 one is that means that the SO switch is not making proper contact. Either the switch’s spring has come off or the slide is not causing it to close at its rest position.
Second Problem: Missing Servo Belt: The belt that drives the threaded shaft is not installed and needs to be to properly test the arm movement. Once this is installed then my question above about pressing and holding Start is relevant.
Lets get this working first before removing any parts or making adjustments.
The servo belt is installed and is new. I probably removed it to take the photo. Secondly, the switch that controls 33 or 45 is working fine, and there's continuity to the connector. Second, could someone tell me what powers the motor at 33 RPM? I'm not referring to the preset or the switch; it must be a transistor or some other component, because at 45 RPM, 3.34 VDC reaches the motor connector, but when I switch to 33 RPM, there's no voltage. Thanks.
Paul, not sure why you are ignoring my troubleshooting questions. You’ve come here for help and collectively we have decades of experience; however, from what you have posted you are not approaching this systematically.  We are trying to guide you by establishing a functional baseline - thus the questions.
Per the manual, there is a relay that switches between speeds based upon either the control panel switch or an optical pulse generated by the tonearm carriage position.
Every time I plug the gearbox into the mains, a new problem appears. Now, no lights come on, either on the gearshift panel or the sensor. And regarding what you mentioned in your answer 69123, the relay that switches between 33 and 45 RPM may not be working properly, as it only switches at 45, not at 33. That said, and since there's no one in Argentina who can repair my gearbox, how can we proceed with troubleshooting my gearbox? If you have a diagram, please let me know, and I'll follow it step by step. I'm sorry for wasting your time...
Paul, in your first post you stated that you just purchased this turntable and it worked until you began taking it apart and lubricating it. Can you please confirm the details as to what worked on it and how you reached that connclusion.
NEXT, as I have stated earlier, no lights should be coming on when you plug the turntable in. On that model nothing should happen until you press the Start button. If you Press and Hold the Start button the arm should move to the center of the table and then reverse and come back. During that process the platter speed will change from 33 to 45. Please put all the belts and platters on and perform this test and report back the specifics of how it behaves.
NEXT put on a record and Press and Release the start button. Report if and where to the arm moves, does the turntable spin and at which speed, and whether the arm lowers.
With the above information, we can begin giving you meaningful directions.
Good morning, Mark. When I bought it, it worked fine, except the belt wasn't the right one, so I cut and glued it to size while I shopped for the original on eBay. In the meantime, I moved the carriage that moves the arm from the motor until I discovered the threaded bronze shaft and the rear steel shaft. That's all I did. Now it doesn't do anything at all. I re-welded some of the wires, and no lights come on anymore when I plug the tray into a 20-volt outlet. Another question, the light seen in this photo, does it come from the tangential adjustment arm or from the IR diode 4D1...?
Attachments (1)
