Problem on beogram 4002, type 5511
Hi, i have some problem on this beogram need you guy's help.
2 of the cable broken in the red circle part, and i not sure whether i connect it correctly. the green and black wire broken.So i just connected it by guess work.
Anyone have similar TT? can you take a photo on this part
The problem now is that when press "Start“button, the motor will run, but it will stop immediately after the hand release from the start button.
Any advice?
Thanks.
[View:http://forum.beoworld.org/themes/beotheme1/utility/link]
I will be opening my BG4002 in the next week or two and will take a picture.  In the meantime, I imagine someone else will beat me to it.
I think there is at least one BG4002 thread (maybe it was a 4000) already in the forum with many pictures.  Did you search the forum for a 4002 thread?
Thank you, Kelvin had send me the picture.
I do browse the post related to 4002 previously, it solve some of the problem then some other problem exist.
I do have the service manual for 5513 which similar but slightly different from 5511.
It seems they are many variant on 4002. Most of the photo /pcb seems different from my 4002.
Lucky kelvin's is quite similar.
Your is type 5511 or others?
