j0hnbarker wrote:
Hi Kevin
I noticed you recently replaced a 800x series turntable with this 4002. How did that compare with the Grado conversion on your 4002? I had a good MMC2 on my 8002 and that took some beating, so it would be interesting to hear what you think the difference is between the decks and proprietary/non-proprietary cartridges.
Hi Mr. Barker.
I was collecting turntables for awhile and bought a Grado Gold to go with a Dual 1229. I knew of Grado's reputation and wanted to try it. I really loved the sound of the Grado but missed the tangent tracking. The Grado in comparison to the MMC is much smoother, has more substance, and is a lot punchier, to my own taste.
I had a 4004 in the past, gave it up for an 8002, and now went back to a 4002 but with the Grado conversion. My objective was to have the Grado and also tangent tracking. Its very difficult if not impossible to retrofit a p-mount to an 8002 because of the thinness of the arm.
I also went back to the 4002 because it is much more solid than the 8000 series which in my opinion has a lot of plastic. Personally, I don't like the BG8000 because it is a transition TT from 4002/4 to 8002. BG8000 has 8002 body but still has the 4002 arm.
I'm particularly happy with mine because in addition to the circuit board rebuild, the arm was dampened to get rid of resonance, which I noticed with my first TT, the 4004. The result is a very quiet TT and I didn't think it was working until the music started.
Best....๐
