Best regards to the participants!
I recently bought a 4004 220v in a package, no one has ever used a deck.
This is not my first beogram, but I have never seen it in such a new state. It turned out that all functions work, and it keeps speed very well, although a logical replacement of radio components is inevitable .. So far, I have serviced the pancake engine, cleaned and lubricated all the mechanisms, made adjustments mechanical parts according to the manual, replaced the tonearm belt. But such an old thing cannot be perfect, even she hasn't seen music. I would not want to create many topics on the forum, it would not be beautiful. I will ask all questions at once.
1. Hood hinges squeal. How and how to lubricate them so that there are no greasy marks and grease leaks?
2. I have not seen an article about the lubrication of the tonearm motor anywhere, it seems I am not able to understand how to disassemble it.
3. This beogram does not automatically turn on 45 x 7 "speed. This is amazing. All functions tonearms work correctly: start, it defines any record size, return. If I press 45 on the panel, then the speed always works. I suspected the sensor and closed it while driving, and immediately solid tonearm errors began. After that, I was completely confused as to why the transparent plastic striped markings did not work ..
4. How does the deck behave if the largest capacitor is dry? What are the signs?
I will be grateful for your help!
