Chris, I am just in the middle of restoring a Beogram 1102 which is virtually the same machine as yours. I've done the mechanics and am on with replacing the veneer on the edges now. Good looking deck, one button contol.
When you first try it, put a rubbish LP on. A common fault with this model means that at the end of play, it doesn't lift the arm and drags it across the record. It's an easy fix though.
You will easily get a good B&O amp for it from that time period for £20-£30 off eBay. Be careful when you get older speakers, they could have foamrot.
By the way, you have just contacted the incurable Beovirus!!😉
Welcome to Beoworld 😁
Andy T.
