Wow, I found an old couple selling their Beogram/Beocenter locally, and picked up their Beogram 8000 in an excellent condition. I paid premium, but it's well worth it. Cosmetically it's in an excellent condition, with clear acrylic cover, good rosewood finish, and just a couple of small scratches on the exterior. It has the original MMC 20CL cartridge. All the controls work. The movement of the arm is smooth, but it makes a small buzzing noise while sliding right to the rest position. I haven't had a chance to listen to the records yet as I don't have the DIN to RCA connector. I bought one from eBay and hopefully I should have it by the end of this week. I'm very excited about this purchase. I have warm and fuzzy childhood memories about B&O turntables, and I hope this doesn't disappoint.
Is there any preventive maintenance I should be doing, or don't fix if it ain't broken? I should probably replace the belts. I hear the capacitors may need replacing, and I'm wondering if I should do preemptive maintenance. The aluminum cover right of the acrylic cover is loose, and looks like the adhesive dried out after 20+ years. What's the best way to repair the cover? Clean up the adhesive residue and apply double sided tape?
I'll probably find out when I hook up the table to my system, but do I need an outboard phonostage? If so do I need MM or MC? I have EAR 834P with switchable MM/MC. I wonder if it's a good match with B&O tables.
