maybe instead of a transmitter, I need an amp with bt connectivity. But i dont like the idea
Input: Beogram & Beosound to Output: Moment & Bt
You are absolutely right, have not thought of that.
I was thinking that the headphones would be able to control the volume output of the BT transmitter. Perhaps not!
Anyway, instead just connect the BS9000’s variable Powerlink output to the BT transmitter, and connect the fixed output (from the adaptor) to the Moment’s line-in.
I am looking forward to learn how that will work on a daily basis.
So, please post the results here.
With the following connection diagram:
Beogram 9000 ---------> AUX (BS9000)
BS90000 (powerlink) ----->splitter ---A-----> Moment
splitter---B---> BT transmitter
the BS9000 can control only the volume of the cd's not the volume of the Aux?
thank you
thank you
What do you mean pass both the BS9000 and BG65000 to the moment? how can I do this?I was answering your question using similar terminology! Perhaps I should have said that my amended solution would pass either BS9000 or BG6500 to the Moment (depending on what source you select on the BS9000, CD or AUX).
