I am facing the following problem:
I have a Beogram 6500 and a Beosound 9000. These two devices I connect with the line input on the Besound Moment and then stream to Beolab 18.
Every time I want to change device I have to change the cables. Is there a small but good quality device to change with a button the input?
Also I want to be able to stream to Beoplay H95 with Bt ( not simultaneously with the Moment)
So I was thinking that this device should have 2 RCA inputs and 1 RCA outpout & Bt.
You have any suggestions on that?
Thank you
