I want to polish a BG4000 platter - that's the heavy one, with the stroboscope markings on the underside. I can't figure out how to SEPARATE the lightweight shiny top portion, from the heavy dull bottom portion, in order to remove the plastic ribs.
BTW - This BG4000 platter is the identical platter found on the Early BG4002 models with the AC motor.
Has anyone done this, or knows HOW to do this?
Menahem Yachad
Jerusalem
