Glueing Beogram TX metal arm cover and metal cover plate surrounding the turntable.
What is the best product to use glueing these cover plates back on? Also, what is your advice on cleaning and prepping both surfaces before applying glue. As always thanks for your help.
zapdady
Any advice on removing the old hardened tape adhesive? Thanks.
zapdady
Thanks, Saint,
I see now that it is easier than I thought. You guys rock.
zapdady
