Hi
I have been fixing beogram 3400 with the intention to listen to 4ch and sq.
I had to buy a few to get lucky to have one with the built-in decoder….
I have been playing with the beogram some days - i just did some cleaning and lubrication inside (motor spindle/idle whell and some mechanic parts) + I changed the roedenstein caps on the decoder.
I didnt do anything to the motor, yet.....everything worked well (even the cd4 diode was lit)
After some days to bg 3400 went down in speed, 26-27 rp...At least one of the others did the same.!!??
Im planning to buy new belts - but i dont think they at related to this problem - the old belt are not that bad.
Now I have cleaned and lubricated the bottom motorbearing lightly (without taking it totally apart) - but i only reached speed after 1 hour. Which is good, and now it starts at the right speed.
Now my questions
- Is it ok to completely take the bearing apart? Doesnt it have to be reassembled very precisely (i mean beyond my skills)
- The motors I have lubricated Bg3400 and Bg1000 (round motor) runs very hot (especially the bg1000) - is that normal?
Mvh baek47
