Greetings,
This my first post and I am extremely happy to be here.
After about a million years I am finally putting together my B & O system. I have a rather nice Beogram 3404. The problem is that it may have been tweaked in shipping. The flywheel is "tipped" so that one "side" is low and the opposite side is high.
As it spins, as you might guess, the platter appears to wobble. However, I have put a .55mm shim on one of the flywheel tabs (I guess you might call them - there are three on the wheel) temporarily, and you'd never know there was a problem.
Outside of the tip in the flywheel, the turntable works perfectly and sounds great.
So, can anybody tell me how to remove the flywheel? I have the schematics, but I am baffled.
Also, my assumption is what appears to be a center shaft on the flywheel is kinked where it attaches to the wheel. Any ideas about how to fix this, or ideas about a solution?
Thanks in advance, and many thanks for reading.
