New member here! I tried to use the search function, but could not find any valid existing threads, so I decided to create a new one.
I want to make and solder my own DIN-adapter cable for my Beogram, but I can not find any "schemetics" for this type of cable anywhere online.
Do any of you kind folks have it and would you be able to share? I have tried and tested a couple of options. This one worked the best:
Red to the left-most terminal.
White to the right-most terminal with a jumper to the 1st from the left terminal.
Ground wire (yellow) to the middle terminal.
All shield wire soldered together and then soldered to the metal part of the DIN-connector.
This works somewhat, but it is still playing with some ground buzz and it is way to fragile, so something must be wrong.
Please advice. Picture of a generic cable added for reference.
