Connecting Beogram 9000 to BL 28’s
I have just taken delivery of a pair of BL 28’s to update my BL 20’s.
so far I am very impressed with the sound. Using Deezer Hi Fi.
Good  bright and  detailed sound with good bass. Much improved on the BL 20’s especially at lower volume.
My Beogram is connected via a pre amp to my old Moment through line in, and then to the BL28’s via Beolink
The sound from the Beogram sounds dull in comparison to the same track streaming direct through the BL28’s with the moment switched off.
Is there a way to connect the Beogram to the BL 28’s without using the Moment?
Yes, I can help. I am away on vacation until Tuesday, but the item in the link below will be available when I return to give a direct connection to the primary Beolab 28 speaker.
As this Beogram  doesn’t have a pre-amp, you will need this pre-amp kit, which comes with all cables needed and full instructions, ready to “plug and play”:-
https://soundsheavenly.com/beogram-record-players/12-2196-pre-amp-bundle-for-bo-beogram-and-all-turntables.html#/36-output-5_pin_din_aux/41-power_supply-uk – please choose the “3.5mm TRS plugs” output option for your speaker
Kind regards Steve.
I'm a little confused about the initial problem. Are you comparing the sound of a song
  • played from Deezer on a Moment connected to the BL28s to
  • played from vinyl played on a Beogram 9000 via a RIAA preamp through the Moment connected to the BL28s
? If "yes", then the difference in spectral balance is most likely to be caused by (in order of probability)
  • different masterings of the track (Deezer vs. vinyl)
  • wear on the stylus
  • weirdness in the RIAA filter's magnitude response curve
Of course, there's nothing wrong with connecting the RIAA output directly to the BL28s Line Input, since the fewer devices in an audio chain, the better (generally speaking...), but I doubt that this will make a big change in overall timbre that you're describing.   If "no" then never mind... :-) Cheers -g
PLEASE READ before sending me a Personal Message.
If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department.
I cannot be a "short circuit", bypassing these communication channels.
-geoff
Thank you for your feedback.
I am comparing as follows:
A song from a specific remastered recording that I have on a new Vinyl,  and on my Deezer HiFi account.
played from Deezer HiFi directly through  BL28s - (Moment is Standby)
to
The difference was quite dramatic. I will check the stylus, its an MMC 1
First, which RIAA preamp are you using?  I would definitely try a direct connection to the line in of your BL28’s bypassing the Moment.
Apologies, I have checked for the preamp type and realised that I switched out my Beogram 9000 for a Beogram 3500 a few years ago. The Beogram 3500 has a built in pre amp, so the Beogram is connected directly to the Moment.
To do a fair comparison I would still connect the 3500 directly to the 28s.
