so far I am very impressed with the sound. Using Deezer Hi Fi.
Good bright and detailed sound with good bass. Much improved on the BL 20’s especially at lower volume.
My Beogram is connected via a pre amp to my old Moment through line in, and then to the BL28’s via Beolink
The sound from the Beogram sounds dull in comparison to the same track streaming direct through the BL28’s with the moment switched off.
Is there a way to connect the Beogram to the BL 28’s without using the Moment?
