Calibrating a BG RX?
I usually use a test record (try e-bay), in my case Hi-Fi Sound 75, to set the stylus pressure by ear, as the scales can be inaccurate on arms, as can pressure gauges - we are trying to judge fractions of a gramme, with static & dynamic friction to take into account, not to mention our judgement of the 'floating' state. If you look back at the Hi-Fi magazine tests of the 70s, the 'optimal' tracking force wa often at variance with the cartridge manufacturers' claims - one may suspect that, since low tracking force was seen as desirable, optimisic claims may have been made by some of them, like acceleration times for cars!
Record wear may lead to a requirement for a less sophisticated stylus profile & a higher tracking force, too. I use an MMC-2 tracking at 1,3g for 'very good' discs, & an MMC-3 at 1,75 for worn ones.
Hello,
There is an anti-skating adjustment at the bottom of the beogram. Have you checked this? Maybe that's a cause of the problem too. You have to set it to separate numbers; one for mmc1 and mmc2, one for mmc3 and one for mmc4 and mmc5.
Greetings,
Ruud
thank you all for the excellent advice; my sound has improved dramatically through cleaning the cartridge and adjusting the tracking force! I'm also looking into the anti-skating...
Best,
Jordan
Hello Jordan and Peter,
I was speaking about anti-skating from the vision of a RX2, apologize. I'm not sure if the RX has something of a anti-skating.
Jordan, have you checked the bottom of the RX already?
